Subject: Re: Upper cabinet door max width
12/2/17
Randy Stone
I have a single upper cabinet in a corner to the left of the sink. A single door here would work well logistically, but it would be 23" wide (37 tall). A real head knocker.
I try to stay under 22" on uppers. I'm wondering what the rule of thumb is for other cabinet makers? Do you think this is a bad idea?
My client is me and I'm stuck on this one.
12/2/17       #2: Upper cabinet door max width ...
B
We try to keep them 24" or under.
12/2/17       #3: Upper cabinet door max width ...
Mike Fuson
I would normally make two doors for that mainly because of warping, I don’t like to go over 19” if I don’t have to. Having said that, I’m working on a kitchen right now that sounds like your exact situation right down to the door size and I’m doing a single door because it’s a mission style kitchen and the stiles and rails are 4” wide so I’m trying to stay away from the narrow doors.
12/4/17       #4: Upper cabinet door max width ...
Alan F. Member
Height needs to be greater than width, see your hinge manufacturers data.
We often do up to 30" single doors in commercial.
Number of hinges increase as door grows in height.
12/4/17       #5: Upper cabinet door max width ...
Keith Newton
Randy, besides going with 3 hinges, rather than centering the middle one I like to locate it higher up where it helps with the tension on the hinge and fasteners.
I've recently seen some doors where the hinges were failing. In both the hinges were 5 1/2" from the top and bottom on 24" tall doors of the same width.
I would locate them as near the ends as the opening will allow.
