Subject: Re: AWS Custom grade
AWS Custom grade
2/13/18
Richard Grant
I am doing a commercial job with white melamine cases and slab laminate doors.
My shop drawings came back and the architect says in custom grade I cannot use particle board core in the laminate doors or in the melamine cabinets. I may be able to get melamine on a mdf core, but is my understanding of custom grade wrong?
2/13/18       #2: AWS Custom grade ...
Rich
what else would you use. Particleboard or medium density fiberboard is recommended for Premium, Custom and economy. only core not permitted for doors is veneer core plywood.
link to PDF of page from 2005 AWI standards.
SProdScan18021317030.pdf
2/13/18       #3: AWS Custom grade ...
Alan F.
You can't make doors our of melamine with a laminate face. Some specs require the back of the door to be the same color as the face.
4.4.7 HPDL Material Rules (From previous column)
CORE shall be manufacturerˇ¦s choice, within the provisions of these standards.
Which allows industrial particle board unless the architects specs say otherwise
A-
2/13/18       #4: AWS Custom grade ...
Alan F.
Richard,
NAAWS I the West Coast (WI) and Canadian standard, its similar to AWS (Replaced AWS for WI and AWMAC).
You can download it for freee at the link below.
Otherwise you need to buy a digital or print version of AWS
US NAAWS Download
2/13/18       #5: AWS Custom grade ...
Dave L
The architect may have misread the finish by surface section, e.g. AWS 2009 pg 247. PB is only excluded for opaque finishes (economy popcorn paper not allowed), not laminate.
WOOD casework OPAQUE finish:
1.2.14.1.1.2.2 CUSTOM GRADE:
1.2.14.1.1.2.2.1 MDF, MDO, close-grain hardwood plywood, or solid stock.
DECORATIVE LAMINATE casework:
1.2.14.1.2.2 CUSTOM and PREMIUM GRADE:
1.2.14.1.2.2.1 HPDL of specified color or pattern. [exterior, interior can be LPDL]
AWS 2009 Casework
2/13/18       #6: AWS Custom grade ...
Richard Grant
Yes, Alan F I am in Canada and I do have a copy of the AWS 2009.
No, I am not making doors with melamine.
I specified on my shop drawings particle board core with laminate on both faces. the architect crossed out the pb and stated as per custom grade no particle board.
I queried this and they referenced section 4.2.7.1.3.2. I think this section refers to casework with an opaque finish, not laminate doors.
Now I am worried. Are they going to say I cannot use melamine with a particle board core for the cabinet boxes?
2/13/18       #7: AWS Custom grade ...
Alan F. Member
Richard,
Go to the AWMAC site, you should be able to get NAAWS from there; that's the latest edition. I think you are right, the architect misread the spec unless they have a spec that overrides it.
We sometimes see the comb core spec with MDF faces or "Euro" ply cores in food service. We usually only use MDF at gloss finishes unless its specified.
A-
