Subject: Re: Painted fronts, melamine finished ends?
2/13/18
Gene Davis
Client wants to save some $, but wants painted doors and drawerfronts, white. We've two finished ends conditions, in the laundry and bath, and thought let's just do the white in a color to match the melamine.
We use CNC-cut carcase parts and can do the fixing of the three ends we need to do with lock miters and pocket screws, so as to hide fasteners.
Have you done this? How did it go?
View higher quality, full size image (1779 X 782)
2/14/18       #2: Painted fronts, melamine finished e ...
Edi Silva  Member
Website: silvawoodworking.com
Veneer the ends and paint match the doors and drawer fronts.
2/14/18       #3: Painted fronts, melamine finished e ...
B
We just the exact thing you're describing. It worked fine. Looks great. Customer saved money and knew going in what they were getting.
2/14/18       #4: Painted fronts, melamine finished e ...
Dan Cook
We use melamine boxes when money is an issue and just do painted/stained applied finished ends where needed. We screw them from the inside of the cabinet so there is no finish marks on the finished end. Looks good and the customer saves money. Melamine is tougher than paint anyway so this is a win win for customer.
2/15/18       #5: Painted fronts, melamine finished e ...
Dan Sadler Member
Although melamine isn't my favorite choice, I use it for vanities/ utility cabs when cost is an issue. I've been using one sided melamine for finished ends, one side has melamine and one has what they call paper. Takes paint well. I try to make sure it's held off the floor so it doesn't have a chance to sit in water. For a vanity finished end I would have a shallow toe kick, only 1", on the end.
2/16/18       #6: Painted fronts, melamine finished e ...
You can sand melamine with 240 grit. Then paint it. Sand the gloss off it.
