Subject: Re: Power feeder
Power feeder
2/16/18
Joe J Member
I just bought a used shaper and it has an older feeder on it.
It is an ELECTRO ADDA SpA
Europa 380
I don't have any manual and cant seem to find any info on the webb
The oil is in fact sludge but I can find a drain plug.
Anyone have any ideas?
I hate to try taking this apart but may have no choice.
Any help would be appreciated :-)
2/16/18       #2: Power feeder ...
How can you tell the oil is sludge? Must be a fill hole or something you looked in to make that judgement. Are you asking about what oil to use, or how to drain it?
2/16/18       #3: Power feeder ...
Joe J Member
Yes there is a filler plug and a dip stick but cant find a drain hole. I don't think it has ever been changed as it is black and sludgey (Is that a word?)
2/16/18       #4: Power feeder ...
JP Member
Maybe suck it out with something like this? I use one on the lawnmower so it doesn't drain all over the frame.
https://www.amazon.com/Silverline-919236-4-Liter-Fluid-Extraction/dp/B00PQ8E4VM/re
f=sr_1_6?ie=UTF8&qid=1518835327&sr=8-6&keywords=oil+sucker
2/16/18       #5: Power feeder ...
Just tip it over and let it run out the fill hole. Fill it with new oil, run it for a minute, repeat until it looks clean.
2/17/18       #6: Power feeder ...
If its that nasty I would either crack it open and rinse it out with brake cleaner and put it back right. I suppose you could put some solvent/degreaser in the fill hole and run it a while and dump it repeatedly through the fill hole but if I were going to rely on it for anything Id just crack the case in half and wash it out spic and span and start with fresh. Likely when you crack it in half you may find a drain plug hidden somewhere in the paint.
2/17/18       #7: Power feeder ...
Joe J Member
good advice I am just afraid without a drawing I could pull it apart and some spring loaded piece would fly out at me and I wont be able to get it back together.
2/18/18       #8: Power feeder ...
Gerry
"without a drawing I could pull it apart and some spring loaded piece would fly out at me and I wont be able to get it back together."
Sounds like the voice of experience talking there ;) Don't ask how I know that ;)
2/18/18       #9: Power feeder ...
Joe J Member
So true, If you've been a tradesman for any length of time than this is an eventuality.
Anyway, as bizarre as it is I did end up turning it upside down and flushing the sludge out of it and refilled with come good oil.
It never ceases to amaze me however the engineering that goes on. Who would design no less manufacture a oil sump with no drain plug? <;0
I don't believe this feeder has ever had its oil changed. HMMM maybe planned obsolescence!
I wish I knew where to get a manual or acad drawings or ???
Anyway (for the second time) Thanks for all the input
2/18/18       #10: Power feeder ...
We're not talking about flipping a car to change oil, it's just a power feeder. I still don't see the problem, especially since it works. How often do you have to change the oil anyway? Not often enough to complain about it would be my estimate.
2/22/18       #11: Power feeder ...
Todd
My Honda mower which I believe is the best $600 mower out there has no drain plug. you drain the oil out the fill. Less parts, less manufacturing cost... Works OK for all the more often you need to change the oil. Feeders are similar in my experience...
