Subject: Re: Case Clamp and Finished Ends
2/23/18
Stewart Member
I need some advice. We are seriously considering adding a case clamp to speed up assembly. However, 95% of the time, we do not use applied finished ends. Our finished ends are part of the cabinet construction and I typically stain and finish before assembly. Is it reasonable to think I can still do this or will a case clamp damage my finished ends making it necessary for me to sand and finish after assembly? What have you found works here? Thanks for your help!
2/24/18       #2: Case Clamp and Finished Ends ...
Dan cook
Whatfinish are you using. We use Campbell’s magnamax and as long as the finish has had at least 6-8 hours. Dry time we have not experienced it to be a problem.
2/24/18       #3: Case Clamp and Finished Ends ...
Paul Miller
Be sure that your clamps do not have any dried glue on them. Also, you can put a piece of scrap melamine or clean plywood between your clamp and the finished side. Al;so, put a scrap piece under the finished side as well. We do it all the time, rarely a problem.
2/25/18       #4: Case Clamp and Finished Ends ...
Hen Bob Member
We do it all the time, use a clean sheet of cardboard as a cushion. As Dan said, let the finish completely dry
2/28/18       #5: Case Clamp and Finished Ends ...
Stewart Member
Hi Guys,
Thanks for your responses - that's exactly what I was hoping to find out!
