Subject: Re: tambour doors
tambour doors
3/26/18
jay Member
I need to build two cabinets that have vertical tambour doors. The opening is 36" wide and 48" high. The tambour will be made from oak. I have not been able to find commercially available oak tambour that size. So my question is: Is it too heavy? Is there a mechanism that can assist lifting the door? Is there some information somewhere else on this site? I've looked but haven't found anything that discusses a tambour this big. Thus my question. I would appreciate any advice you my have on this. Thank you for your help.
3/26/18       #2: tambour doors ...
D Brown
So you said vertical , a roll top desk usually has horizontal tambour, will it have a split in the middle ?
3/26/18       #3: tambour doors ...
Bruce H
I am guessing you want it to roll up vertically? I have made those in that size for a TV cabinet. The tambour is a bit heavy so it needs to be held when closing. If they let it go it will slam, hate to have my fingers under there.
If you thought about it you could use a piece of shock chord that picked up some of the weight just before it closed. maybe a pulley system to thread it over the top. it would be a lot of fooling around to make work.
3/26/18       #4: tambour doors ...
jay livesey Member
I guess I wasn't very clear. The tambours run horizontal and the door opens vertical or upward.
3/26/18       #5: tambour doors ...
Does the tambour go over the top and store in the back of the cabinet when it's open? One issue with heavy tambours is the stress on the canvass when you close it. You have to pull all that weight and slot friction through a single board on the end of the glueup.
3/27/18       #6: tambour doors ...
jay livesey Member
Yes it would need to go over the top. So maybe I need to make it interlocking or a cable system? Would there be a way to roll it up at the top? Are there mechanisms that will assist or balance the load? I am thinking that maybe I will need to change plans and have the doors open to the sides. The customer is flexible so that is an option. That maybe has it's own challenges? Thanks for your help.
3/27/18       #8: tambour doors ...
Keith Newton
Another way to join them besides gluing to canvas, is to drill holes through the edges and string them together with a loop,, connected together in the back with a spring to keep them tight if they gain or loose moisture.
If you build it in the shop with a removable back, you could easily figure out how to have a block on a spring that gets stretched as it goes down. Standing behind it with everything in place, while pulling on the top of the spring until it lifted would show where to connect the top of the spring to the side or back.
You can get an assortment of springs at any ACE hardware, so if you go in with and idea of how much weight and how long the pull needs to be will give you and idea for where to start.
3/27/18       #9: tambour doors ...
jay livesey Member
I think that sounds feasible. Maybe if I also had a set of springs and block in the back for it to land on as well, to reduce the shock?
3/28/18       #11: tambour doors ...
D Brown
Usually I make a lead strip or handle with a C cut or finger well at the bottom and it gets screwed on from behind the tambour so its thicker and gives some integrity to the bottom edge. Also you can try a counter weight hanging off the back end maybe.
5/4/18       #12: tambour doors ...
jay livesey Member
So in the end I decided to make the doors move side to side rather than up and down. It has worked out well so far. The oak slats are 5/8 by 3/4 glued to canvas. Opening is 48" tall buy 78" wide. The track is 5/8 plus wide plus. I shellaced three track and waxed it. My only concern is that the narrow oak slats may warp over time. Time will tell. Appreciate all the advice. It went better than I expected and the customer is pleased.
View higher quality, full size image (2576 X 1932)
