Subject: Re: Drawer Box Notcher Selection
5/31/18
Bob Stern
We are in the market to purchase a drawer box notcher.
There only appears to be only 3 options
Pinsky
Hurst
and Circle T
Anyone who has used these machines care to offer an opinion?
Anyone know of any other options?
6/1/18       #3: Drawer Box Notcher Selection ...
Dustin orth
I set up a small shaper with a carbide insert tip cutter. If you have the room for 2 shapers, I would do it that way. Look at the video I made up, its way cheaper than buying a large dollar new machine.
https://youtu.be/6yvrhsIbhP8
6/6/18       #4: Drawer Box Notcher Selection ...
Harold morantz
Website: http://morantz Cabinets.com
We make our own drawers and use 1/2 or 5/8 bottoms. We cut sides of drawers to the height we want and fronts and backs 1” shorter for 1/2” ply bottoms or 1.125” shorter for a 5/8 bottom. We pocket hole bottom to sides and nail bottom to shorter front and back, this eliminates the need for any notching altogether and makes a really strong drawer.
6/6/18       #5: Drawer Box Notcher Selection ...
Bob Stern
We decided to make our own.
I purchased the cutting wheel with insert cutters from Pinske. A little pricey, but we do only 1/2 baltic ply and this looks optimal.
I found a new 3 hp Delta Unisaw without the fence for $1,100. Will need to have a machine shop make an arbor adapter,$80.
Don't know whether I will modify it to move upward as in the pinsky machine or just put a sliding cover over the blade. I will mount a drill as well. I just know that I will be in for 3 to 4K instead of $10.
Finally sourced some slides that will work for us that only require back notching.
Will let you know how this turns out. Its behind some other projects as the slides will not be available for 90 days.
