Subject: Re: powermatic 1988 model 66 problem
7/13/18
Makindust2@aol.com
I have a powermatic 1988 model 66
I have used these for years ,but this saw when I raise and lower the blade it moves the blade from side to side. By as much as 3/16 ". Anyone else ever experience this?
What is the fix?
Thanks in Advance
7/15/18       #2: powermatic 1988 model 66 problem ...
Karl E Brogger
There's a square head bolt that goes into the shaft the trunnion pivots on. It's kind of dumb design, but look at an exploded view from the manual and it'll make sense.
I had it happen about ten years ago, I remember replacing a snap ring on that shaft too.
7/15/18       #3: powermatic 1988 model 66 problem ...
Karl E Brogger
Here's a thread I had on it when I asked for help on SMC
https://sawmillcreek.org/showthread.php?164267-What-a-dumb-design&highl
ight=
SMC thread
7/15/18       #4: powermatic 1988 model 66 problem ...
John Skip Moore Member
Thanks so much Karl
7/16/18       #5: powermatic 1988 model 66 problem ...
Hi Karl, You were correct on the call with the problem. The square head screw was not tight at all. It is all good now.
Thanks again
Skip
