Subject: Re: p-lam door core
p-lam door core
8/13/18
Michael  Member
Would there be any advantages to using MDF over particle board on doors which will have p-lam on both faces, 1mm edgebanding all 4 edges and will use Blum Inserta hinges? Just curious if the little bit of extra $ for MDF will gain us anything. Thanks for the input!
8/13/18       #2: p-lam door core ...
Bruce H
I don't see an advantage using MDF over PB.
8/13/18       #3: p-lam door core ...
Alan F. Member
We use MDF for high gloss
Alan
8/19/18       #4: p-lam door core ...
Larry Schweitzer
If you are spraying solvent borne contact the stringy nature of it will telegraph on high gloss. If you are using a glue spreader and a press, or water borne contact, either MDF or P Bd works fine.
Our normal practice is 2mm pvc banding on PB core, water borne adhesive, Inserta hinges. If the architect specifies MDF we use that. The PB is always "industrial grade." Not box store stuff.
