Subject: Re: PM 66
PM 66
10/10/18
Mike Member
Hello all, I have a paramedic 66 I bought back in 2000. I have not use this awful time over the past 18 years. I just started cutting up some MDF and started hearing a sort of squealing sound and now it kind of smells like burnt rubber in a way.
Also, my blade seems to stop at a faster rate than it used to. Do you guys think it is something to do with the belts and or the motor? I am not really looking forward to purchasing a new saw and or having to replace the motor, etc., because I know for as old as this machine is, it would likely not be worth fixing.
10/10/18       #2: PM 66 ...
duster
Squealling sounds? Burnt rubber smell? Your belts are most likely shot, especially if they're the original ones. Buy some new ones, get them installed and tensioned correctly.
10/10/18       #3: PM 66 ...
Mike Member
I found the problem. One of the belts fell off the pully. Is there anyway to get this back on without taking the tension off? I don’t know how to put the tension back on, nor do I know the amount of pressure needed.
10/10/18       #4: PM 66 ...
duster
The problem is not that the belt fell off. That's just a symptom of the problem, which probably is old, stiff, cracked, and improperly tensioned belts. Buy a couple of new belts, (they're about $3 each online) find a youtube video demonstrating the procedure, and get it done. It's a 10 minute job.
Do yourself a favor and fix this right before you hurt yourself.
10/11/18       #5: PM 66 ...
Mike Member
Duster,
I have a local macine maintenance company who helped me in the past. He called me back and told me how to remove/replace the belts. You are right, it will be a 10 min job.
Thx again!!
10/11/18       #6: PM 66 ...
duster
Mike - I'm glad you're taking care of this and fixing it yourself. Belts don't last forever, I change the ones on my 3 saws every 2 - 3 years. If you're using a jointer and a planer, I'd check those too before they fail...
10/12/18       #7: PM 66 ...
KCR
Mike, as you are working on the belt replacement, be sure the 2 pullies are aligned with each other properly. If not the belts will wear out pretty quick again even if there new. The may also continue to squeal.
