Subject: Re: Full overlay (19mm) pocket door slides for 1" thick doors??
10/31/18
Joe Seremeth Member
Website: http://woodlab.me
Does anyone here know of a pocket door hardware solution for full overlay 1" thick cabinet doors? My specific instance would be coffee station (appliance garage) 52"h x 36" w x 24" d. Doors are slab, 1" thick MDF, veneered, 52" x 18"... I have been down the KV8090 / 8091 road to the point of mounting Blum thick door 110° full overlay in place of the Salice hinges that KV offers with the kit. The issue is the thickness of the door against the cabinet side. 3/4" thick doors work of course, but with 1" doors, the face of the door hits the cabinet side. One work around we are considering is remaking the cabinet with 1/2" sides, but this would be a last resort. I would love to find a hardware solution that can achieve the goal with out rebuilding. Someone must have done this before... Thanks in advance for any shared knowledge.
10/31/18       #3: Full overlay (19mm) pocket door sli ...
Matt Calnen
Rout out the area where the hinge goes so it’s only 3/4” thick at that spot. I do this quite often.
10/31/18       #4: Full overlay (19mm) pocket door sli ...
Joe Seremeth Member
Matt - Great idea, thanks. I have done this in the past under different circumstances. My only issue in this instance is seeing the void in the door edge from the side. With the KV 8091 there are 4 hinges total, so you would see the 4 spaces on the door edge... I am still hoping someone knows of hardware that will get me there, but we are going to try it and see if we can live with it. Thanks for your input.
10/31/18       #5: Full overlay (19mm) pocket door sli ...
Skillet
Have you checked Accuride? They make some nice pocket door guides.
11/1/18       #6: Full overlay (19mm) pocket door sli ...
I think it's the Accuride 1234. Or maybe the 123 and you use a thick door hinge which is a 40mm hinge instead of the standard 35mm hinge.
