Subject: Re: Used edgebander
Used edgebander
11/6/18
Jonathan Mahnken
Would you buy this bander for the right price? Are there any inherent problems with this model
View higher quality, full size image (1600 X 1194)
11/6/18       #2: Used edgebander ...
Bruce H
Does it work? How much do they want for it? Used machinery can provide good value for the money but you might have to put something into it to make everything work.
I recently bought a used construction drill, didn't run. A little work, figured it out and it runs now.
11/6/18       #3: Used edgebander ...
Hen Bob Member
We started with one of those. If it has the angle grinder type trimmer motors walk away.. FAST! there is only on company we could find that would repair them and it was expensive. If it has the newer type motors and its basically free maybe.. Ours was nothing but problems.
Good luck
Henry
11/6/18       #4: Used edgebander ...
Jonathan Mahnken
Thanks Hen Bob. I kind of figured that would be the case, and yes it does appear to have the type of trimmer motors you speak of, so ill steer clear
11/13/18       #5: Used edgebander ...
Dave L
My 1432 has trimmer motors. Admittedly not heavily used, but no issues. Having been warned of the potential expense, I blow the dust out of the trimmers often and check the brushes regularly.
11/13/18       #6: Used edgebander ...
Dave L
...router edge trimmers/grinder end trimmer.
The bodies look pretty standard, like a bosch or PC, etc. might work. I thought only the left hand rotation edge trimmer was the issue, but it appears all you need to do is switch the brush leads.
http://www.woodweb.com/knowledge_base/Reversing_a_Routers_Rotation.html
$325.00
4-2018
Rebuild/rewind price is based on our costs at the date shown
http://eurtonelectric.com/catalog/motors/holz_her_2390_208_3426_flush_trimmer_moto
r_repair
