Subject: Re: Door stops for Inset Face Frame Style
6/19/19
Stewart Member
Okay, coming from primarily a "euro" style shop, what are you guys doing to give your doors something to bump against when you are doing a face frame with fully inset doors and drawer fronts? The drawer fronts seem a little easier to deal with as I can register the glides to stop the front perfectly with the frame. The doors are a little harder...I've been using a short wooden block that hangs down into the space to capture the top corner of the door but feel I need something for the bottom as well to help keep it in plane. I've tried the fastcap euro stops - and, while they work well with lots of adjustment room, I'm not sure I like having them mounted to the bottom of the cabinet as it could impede sliding items in and out and possibly catching on something. I'm also not crazy about cutting a lot more material to create an additional fixed bottom shelf to provide a door stop and lose that additional 3/4" height space. Does anyone have a better solution for this?
6/19/19       #2: Door stops for Inset Face Frame Sty ...
Eddie
https://www.hafele.com/us/en/product/door-stop-for-single-doors/000000bb000015d500
020023/
They have for single door, double and for face frame mount.
6/19/19       #3: Door stops for Inset Face Frame Sty ...
Matt Calnen
I basically make a euro box with edgebanding and the plywood hangs into the opening 3/8” on all sides. Use a half crank hinge and a 0 plate. I attach the box to the frame with a separate strip of plywood with pocket holes in it. Kind of a pain but my customers love the look and it helps set me apart. You could just hang the top and bottom into the opening and make life alittle easier.
6/19/19       #4: Door stops for Inset Face Frame Sty ...
Stewart Member
Thanks, guys! Matt, i'm very intrigued with your idea - will have to toy with changing some of my parameters but that sounds like a great solution. Thanks!
6/21/19       #5: Door stops for Inset Face Frame Sty ...
The shop I was trained in used to edge band the bottom of the upper box. Leave about 3/8” exposed. The only issue was the face frames had to made 13/16” of inch thick. Otherwise the door would bind.
We got in the habit of using Blum soft closers. The customers love the closing feature. We love the fact it solved the longtime problem you are experiencing.
Are they attractive... no. Does anyone care...no.
6/28/19       #6: Door stops for Inset Face Frame Sty ...
Tracy Yarborough  Member
I use a 1/2" false bottom placed inside cabinet 1/8" back from face. On upper cabinets, I place a false top panel as well.
On base cabinets, I place a stretcher at the top of the door 1/8" back, 1/2" down as to match the false bottom.
1/8" reveal allows for slight door warp adjustment and for the use of bumpers.
