Subject: Re: toe kicks
toe kicks
10/8/19
Gary
We currently build loose toe kicks on our cabinets. Thinking of going with "normal" toe kicks with notched cabinet ends like most do. Short of drawing up several jobs, does anyone know how sheet stock yields on the cnc one way vs. the other?
10/8/19       #2: toe kicks ...
Really depends on how many cabinets and their sizes if you can get an efficient nest per sheet. I've had good and bad yields with cabinets of various sizes.
Just recently I had a good yield with two 12dx36x60 shelving units. Although that's not a lower.
10/8/19       #3: toe kicks ...
Oggie
I get six base cabinet's sides from one 4'x8' if the cabinets are with loose toekicks or four sides with "normal" cabinets. Anyway, if there are 3 or more cabinets in cutting list pretty much the yield is same for both styles, i.e. all of the board's space get used very efficiently.
That being said, most of the cabinets I make have all the parts (except the backs) made from the same material, so nailers, stretchers and drawer fronts usually fill remaining areas of boards till only narrow stripes (mostly less than 2") are left.
Used to do "normal" cabinets in the beginning and than switched to leg levelers and detachable toekicks and I'm not going back, unless I'm sometimes forced to.
But I am a one man shop and switching to different material for different parts of the cabinets creates waste of time and energy that is, in my case, more expensive than waste of material (like when I cut nailers from the same colored melamine board that I use for doors).
But, your volume and your production setup may yield different results.
I cut my parts manually, and recently I have discovered that I'm much faster in cutting when I nest similar parts on the same board, because alignment is better and many parts "share" one same rip or cross cut. Of course, the yield is not as good as when everything is mixed all over the place, but for the size of my typical project I spend maybe one or two boards more than necessary, but save 1-2 hours in time, which is the price I gladly pay, because two board costs ~ $60-80, and I can make $400 dollars worth of cabinetry in 2 hours, so to try to save on material at the expense of time would be stupid in my case.
On the other hand, if you're cutting your parts on the cnc, this is probably irrelevant to you :)
10/9/19       #4: toe kicks ...
MarkB Member
Im in the Oggie camp. CNC, get 6 full sides per sheet out of standard height boxes. Detached kicks are my preference. If its anything other than that box height all bets are off.
There is a lot of info in the archives here with regards to detached kicks, full height ends, and so on.
10/10/19       #5: toe kicks ...
Matt
One of the better aspects (aka, selling points) of detached kicks is water resistance.
Any house could have a flood, and cabinet sides that are notched to go all the way to the floor are at more risk of water damage/delam in a way that just ruins the cabinet. That's a pretty good selling point for places like bathrooms and busy households.
