Subject: Re: Omec Bits
Omec Bits
10/22/19
Matthew Member
Just purchased an Omec dovetailer. Looking for bit and supplier recommendations. Machine came with a dovetail bit but looking for best straight bit to use. Anyone with experience care to give an opinion? Cheers. Matt
10/22/19       #2: Omec Bits ...
Mark Member
Matthew,
What model Omec did you purchase? Different models take different bits.
If it's CNC controlled you'd want a sprial bit which Vortex Tool carries and I would recommend.
If it's one of the bits that's adjust by an eccentric then maybe Vortex might carry that one as well.
Mark
10/22/19       #3: Omec Bits ...
What kind of material? Solid or ply?
I use a Cantek dovetailer, I've had the best luck with the solid carbide two flute bits from akhurst. We do solid birch.
I don't know this for certain, but I think the omec machines use the same style bit.
Vortex sells a couple of variations that I would like to try if they are. I think the chip breaker type could do well.
10/23/19       #4: Omec Bits ...
Matthew Member
It is the 750 CN, cnc controlled model. We are machining hardwoods. I'll look at Vortex, we buy a number of other items from them. Thx.
10/25/19       #5: Omec Bits ...
Mark Member
Matthew,
You need the Vortex bits for sure. The helical spiral carbide bits are the best.
Mark
