could use some Help psa cracking?
3/7/15
Rob Member
Hi I am doing a cabinet refacing using psa alder veneer and from handling it with my slitter it keeps cracking.
my guess is because it had been sitting for about 3 days before the install.
I finish using Mohawk 2 coats sanding sealer, sand 320, 2 more coats sanding sealer, sand 320 and 2 coats lacquer.
I know lacquer can get brittle when cured I need to see what you guys are using to keep it flexible until I go to install on a cabinet reface.
Maybe add some retarder to keep it from completely drying underneath? Or is there maybe a flex agent I can add to it? Thanks for any help.
3/7/15       #2: could use some Help psa cracking? ...
Charles
That's a lot of finish. Try 1/1/1 vs. 2/2/2 coats. And keep it thin.
3/7/15       #3: could use some Help psa cracking? ...
You are putting too much sealer on! One is enough. Sealer is soft. Keep the total thickness build down. Lacquer sets hard. Too much and it will check down the road. It won't be able to move with the veneer. Is this the first time you've had problems slitting paper backed veneer? If the wheels on a slitter wear even a little they will want to bend over the material before breaking it off resulting in the cracks you see. Alder is really weak.
3/7/15       #4: could use some Help psa cracking? ...
Rob Member
Thanks I will have to try that.
I know that psa comes pre- finished in a rolI wonder if they use lacquer or maybe something different?
