Hinges for Entertainment Center
3/10/15
Jay Rump Member
Website: http://www.blanchardwoodshop.com
I am designing a cabinet for a flat screen TV. The cabinet is 60" wide 72"height and 11" deep. The customer wants doors to cover this 60" width just looking for suggestions how I can hinge four door panels on this cabinet. I was thinking of using blind corner hinges to connect to doors together where it would work more like a bi fold any suggestions would be appreciated.
3/10/15       #2: Hinges for Entertainment Center ...
Duster
I've done bi-folding (and tri-folding) doors for TV cabinets many times. Usually in conjunction with pocket doors hardware. For the bi-folds I usually use no mortice butt hinges. Easy to install, and they're not visible because they're behind the doors.
3/11/15       #3: Hinges for Entertainment Center ...
Dan
Hafele offers an excellent bi-fold door hinge, Aximat, #343.91.600, which will spring open and spring closed. It is concealed, adjustable, and easy to install in 35mm hole.
Now you still have the issue of hanging two 15" panels off of hinges on one side. The Hafele/Hawa Bi-folding Concepta will do this handle this application beautifully if you have the budget.
Leporello, also from Hafele, will suspend and guide the panels to each side if you are only folding them and do not need to pocket them as well.
Pictures show Aximat bi-fold hinge, Leporello suspension fitting, and track.
I hope these ideas help.
