Face Frame Hinge with restrictor
4/19/15
Kevin Member
Does anyone know of a way to reduce a face frame hinge (blum compact 38N) to only open 90 degrees? I didn't realize the little restrictor clips do not work on these hinges. Does anyone else make a 90 degree face frame hinge with a 1/2" overlay? Thanks.
4/20/15       #2: Face Frame Hinge with restrictor ...
Andy
You can use a Blum clip on hinge with a face frame baseplate.
A
4/20/15       #3: Face Frame Hinge with restrictor ...
Chuck Member
Part number for compact restriction clips is
38C315B3 they limit door swing to 86 degrees
4/20/15       #4: Face Frame Hinge with restrictor ...
Kevin Member
Thanks for the responses. The restrictor clip is exactly what I need.
