Poor quality veneer core
5/11/15
Terry Member
Are others out there having trouble finding a good quality veneer core for hardwood plywood? We get a lot of voids just underneath the thin veneer layer. This ends up with ripples across the finished product, and a chance that the veneer could "collapse" in the void.
5/11/15       #2: Poor quality veneer core ...
JimHerron
I switched to MDF core for hardwood veneered panels a long time ago for this very reason.
You can deal with frustration of the current product, switch cores or pay thru the nose for a better VC panel if you can find it.
5/12/15       #3: Poor quality veneer core ...
Max Neu
I switched to a product called Armor Core.It's a plywood core that has an 1/8" layer of MDF just below the face veneer on both sides.The advantages are;
Stronger than solid MDF core, lighter than solid MDF core, accepts stains very nicely due to the flat/void free surface of 1/8" mdf surface below the show face of the veneer..I would never attempt to stain regular veneer core plywood anymore with the way the quality has gotten to be..
5/12/15       #4: Poor quality veneer core ...
mike
yes, and its very frustrating. Started using the mdf outer core as mentioned above from time to time or sometimes I buy 1/4 mdf core and laminate over 1/2" prefinished for my ends
5/13/15       #5: Poor quality veneer core ...
Terry
Thanks for the suggestions. We like the quality of MDF core, and also Armor Core, but, most of our work is in bars and restaurants. Need to use VC for the amount of water, and moisture involved. Columbia is making an MPX core, which is said to have a FULL layer of void free core under the veneer. This is just not true. We'll keep looking. Thanks.
5/16/15       #6: Poor quality veneer core ...
I'm in Canada. My supplier has just brought in a poplar veneer core that is the best ply I have ever seen. The core is void free one piece per ply - no lapped joints. The face is a one piece poplar knot and patch free.
The brand is Garnica from Spain.
The best part is I have seen the lifts of plywood at the warehouse for a few weeks and they remain flat. No top sheet curling up like a potato chip. Also the sheets are low weight maybe half the weight as MDF.
Robert Bury supplies in Canada.
