SHAPE & SAND SANDING HEADS
5/14/15
RICK THRASHER
Website: http://DANDHCABINETS.COM
I AM PURCHASING SANDING HEADS FOR A 4522 UNIQUE SHAPE & SAND. I HAVE RECEIVED BIDS FROM ARMINIUS TOOLING, & TURBOSAND. THE BIDS ARE VERY DIFFERENT ARE THESE TWO PRODUCTS COMPERABLE? PRICE IS ALWAYS A FACTOR, BUT QUALITY IS MOST IMPORTANT. IF YOU USE EITHER OF THESE SANDING WHEELS I WOULD APPRECIATE YOUR INPUT.
5/15/15       #2: SHAPE & SAND SANDING HEADS ...
TomB
The differences in the heads is a ton. The Arminius heads are a full rubber head that matches the profile of the cut. The turbosand is a generic head with plastic covers that match the profile. I have both and lean toward the Arminius as doing a better job if you are running the same profile all the time. If you are switching profiles a lot and don't want a head for each, the turbosand is the way to go.
