Trash can push out slide???
5/21/15
Dan Cook Member
I am looking for a slide or hardware that will allow a client to push on the trash can rollout and it will open. They want it so when their hands are dirty they can bump it with their knee and it will open. I know there are motorized units for this but this is too expensive. The pop out slide that I got from the supplier just doesn't have enough pushing strength due to the weight of the trash can box...any suggestions?
5/21/15       #2: Trash can push out slide??? ...
Dan
Blum "uno" need power but that expensive. About 150.00. IMHO if your customer can't pay that then they can suck it up and bend over to open the pullout.
5/22/15       #3: Trash can push out slide??? ...
Salice "Push" should do it for you if you are building your own trash pull-out. This is an under-mount, self opening, full extension slide and installs just like the soft close version. It is prices similarly as well.
Salice also offers kits that include the trash can (several sizes) and the slides.
Both are available Dan, through local distribution in Columbus.
View higher quality, full size image (1920 X 1280)
5/22/15       #4: Trash can push out slide??? ...
Dan Cook Member
Unfortunately I can't use an undermount slide as the type of unit I have built will need side mount slides. It is going to slideout with the door. Also I don't have the space allotted for the premade ones. This is a fairly narrow cabinet.
5/22/15       #5: Trash can push out slide??? ...
Dan, is it narrower than 12"?
View higher quality, full size image (2192 X 762)
