4x24 PC belt sander
6/14/15
Hello everyone!
We have a pc 4x24 belt sander at work. When i use it, i notice its not sanding entirely flat and its almost like its missing spots. I replaced the metal plate with the cork attached and im still getting the uneveness.
Experience is not the issue at all, as ive used this exact belt sander for years, but the 3x21 model.
What else could cause it to not sand evenly? I'm a bit puzzled with this one, as ive never come across this before
6/17/15       #2: 4x24 PC belt sander ...
JohnB Member
I think it's a heat issue, the metal plate gets hot and starts to wrinkle a bit. I switched from the cork to a graphite pad under the metal and it solved the issue. I can't remember where I got it but seems it was readily available on internet.
