cnc or laser cutting inlays
7/10/15
Dan Cook
I am looking for a source that does laser cutting of veneers for inlay work. Also someone who does the same but with CNC routers. I have googled it but must not be using the right terminology as I keep going down blind alleys.
7/10/15       #2: cnc or laser cutting inlays ...
John S  Member
Hi Dan,
You could try Eggers Industries, or Architectural Forest Products, I know both of them do laser inlays.
I don't know of anyone that specifically does CNC inlays.
I would search for terms like veneer inlay, sketch face veneer, marquetry, laser veneer inlay, etc.
7/10/15       #3: cnc or laser cutting inlays ...
Dan Cook
I don't need them to assemble or anything like that. Just to do the cutting of the pieces so that I can assemble them. These would be custom inlays not necessarily stock items.
7/10/15       #4: cnc or laser cutting inlays ...
John S  Member
I'm not sure anyone will want to just cut the veneer pieces for you, but you can ask.
The risk I see in doing that is breakage and shrinking/swelling of the veneer inlays between the time they get cut and into your hands. Even very slight shrinkage will end up with visible open seams, and of course swelling will keep the pieces from going together properly too.
I would suggest you look into purchasing your own laser. You can get a small one fairly reasonably these days.
7/10/15       #5: cnc or laser cutting inlays ...
Dan Cook
I am not sure what "reasonable" is but I need to see if there is a market here first before getting into a machine. If we can support it I would love to have this as an offering to customers.
7/10/15       #6: cnc or laser cutting inlays ...
Just go to a local trophy shop for the laser work. If you provide DXF files, the cost will be considerably less. CNC is going to be a tough one. Holding the veneer and the small pieces will be the tough part. You won't get final work from the CNC since you will have to sharpen corners, or accept radii on all the inside corners.
7/11/15       #7: cnc or laser cutting inlays ...
james mcgrew
Website: http://mcgrewwoodwork.com
Not sure I can help, I do know some who can do this, I use the Vectric Inlay toolpath to do this reasonably Often, also for those with machines look at the Donek Knife , this guy has really figured this out. the "Jazz Player" was done by a member of the CAMheads forum and posted yesterday,
View higher quality, full size image (1141 X 856)
http://donektools.com/
