Bifold hinge with 4-5mm drill distance
8/18/15
I goofed on a job. A cabinet with 2 doors was supposed to have a bifold hinge at center and I hinged each door to sides of cabinet. I'm hoping there is a bifold hinge which will allow me to flip the door and use the existing 35mm and 8mm holes drilled at about 5mm from edge of door to hole. Please please please a solution
8/18/15 #2: Bifold hinge with 4-5mm drill dista ...
In other words, the doors are in plane with each other and need to be hinged together.
8/18/15 #3: Bifold hinge with 4-5mm drill dista ...
Hey Chris,
This is what we use and its the same boss hole set up for our Blum hinges.
I'm sure Hafele have similar.
http://www.wilbrad.com.au/shop/productdetails.aspx?pid=2097&name=A
djustable-Centre-Hinge-For-Concealed-Folidng-Door-Track&cid=503
Cheers Marty
8/18/15 #4: Bifold hinge with 4-5mm drill dista ...
Marty, link didn't work.
Thank you! Blum would be ideal as that's what the other hinges are. I'd ask the rep tomorrow but I'm afraid he won't get back to me for a day and that's too late...gotta fix the mistake pronto
8/19/15 #5: Bifold hinge with 4-5mm drill dista ...
Hey Chris,
Google "Wilson and Bradley cabinet hardware" its an Australian site but it will give you an idea.
Then in the Wilson and Bradley search window type "TKC382". Its not a Blum hinge but it suits a 35mm boss hole.
Like I said I'm almost positive Hafele have the same type of hinge.
Cheers Marty
8/19/15 #7: Bifold hinge with 4-5mm drill dista ...
Hettitch folding door hinge 1 030 883
mounting holes wont line up but the wings do cover the blum holes .
8/20/15 #8: Bifold hinge with 4-5mm drill dista ...
Apparently the hectic hinge is a very special hinge. None of my suppliers stock it...3 weeks lead time for 3 hinges. WTF?!
Thanks door shop (I'll find it elsewhere I hope) and Marty
8/20/15 #9: Bifold hinge with 4-5mm drill dista ...
"Hectic" means "hettich" in computer apparently
