Given a 10k budget for a bander...my options
8/21/15
Carmine Member
That's the amount I was given to work with. Maybe I could stretch it to 15k. Can I even consider a new purchase in pot/cartridge machine? Will be running wood veneer 70%/pvc 30%.
I'm thinking I will be forced to go used but feel very uneasy unless I had good tech support. I'm thinking my best bet would be to find an independent tech first, should such a person even exist then start shopping.
Do you guys have any suggestions for my situation.
8/23/15       #3: Given a 10k budget for a bander...m ...
Chris
I have a amt machine now made by safety speed. They sell new for 10k. Glue pot and a super basic machine. They were at the Vegas show and I got the scoop for maintenance. After lots of trial and error I e now got it dialed in. Thus would have been easy had I known the scoop. Amt had a lousy user manual. The safety speed is exactly the same. Great low tech entry level bander. Up to 1mm pvc with end/front flush cut and top/bottom flush trim. It can do 1mm wood or possibly 2mm ( never tried 2mm) and laminate strips but you have to disengage the cutters for end and front chop (they're guillotines)
9/20/15       #4: Given a 10k budget for a bander...m ...
I had the AMT bander with glue pot described above for several years before
I retired and I loved it. Best 10K I spent, worked very well. The glue pot is well worth the extra $ spent. I had a hot air machine before this and spent more time banding and cleaning and repairing things that went wrong.
