Holz-her glue station
10/20/15
Dave Franklin
I've got a 1402 HF bander. The little holes where the glue comes out have become plugged up. I've got the little metal poker with the ring on the end to push into the holes. But it doesn't work. When I push on it, it just bends. I cut off the ring end and put it into my drill to try to drill out the holes and no luck with that either.
I'm not quite sure what to try now. I've had a tech come by who seems to be quite good. And he's able to clean it and get it working while he's here using the same techniques that aren't working for me. But then within a day it's plugged up again.
10/20/15       #2: Holz-her glue station ...
Gerry
Hi Dave,
It sounds like maybe you have some contamination in the glue chamber. Have you tried opening the glue meter up as much as possible then flushing the nozzle with glue? Also might be worth taking out the metering rod and cleaning it and looking for contamination while doing so.
Gerry
2005344AC_EBA12_06.pdf
10/24/15       #3: Holz-her glue station ...
brian
Dave
this is amazing or at least no coincidence.
On friday I had the same thing happen with the same machine. It was a small piece of debris in the glue rod. There is a dial for the glue height setting. Go down to the bottom of this and there are 2 allen screws on the right, unloosen them, remove pin at rear that connects arm, pull out glue rod and clear debris. its a piece of cake.
If you get into trouble call Lee Johnson at Lakeside Industrial
http://www.lakesideindustrial.com/Holzher_Home_%20page.htm
Brian
