Squared corners on cabinet front cut-out -- 0 --
11/10
We have been asked to use a new kind of pull on our cabinets for an up-coming order. It requires a rectangular cut-out in the drawer front (see pictures) that the pull will fit into. We can CNC the basic cut-out, but of course it will have radius corners from the router bit. Any suggestions on how best to square out the corners?
View higher quality, full size image (1936 X 2592)
11/10 #2: Squared corners on cabinet front cu ...
The fronts in the photo look like they were made as a hardwood frame that may have had a rectangular opening for the pull framed into the front and then veneered over. Not making them as shown in the photo?
11/10 #3: Squared corners on cabinet front cu ...
Hi Bob,
We are being asked to copy a now bankrupt company's product, so we're not sure. All I have is a picture. I was thinking it was hardwood banded particleboard core, but you could be right.
Thanks for the response!
11/10 #4: Squared corners on cabinet front cu ...
We square corners every day in plywood. We use a mortising bit in a drill press with a special placement/backer. I would probably not try it in PB. Hardwood sounds like the way to go.
11/10 #5: Squared corners on cabinet front cu ...
Corner Chisel..
Link
11/11 #6: Squared corners on cabinet front cu ...
Square is relative, I just use a smaller tool to clean out corners sometimes down to 1/16 cutter. 99% of the time 1/8 is small enough not to notice the radius. I guess it depends though on how you decide to make these and what quantity.
It does appear in the photos to be a Pb core with solid frame with veneer over, so hollow chisel may not work well. Am I seeing some Pb core at ends of pulls in openings? Solid wood may be a better choice for a small quantity then you could use hollow chisel.
To answer your original question I would probably clean corners with 1/8" tool and then a little chisel if necessary.
Paul R
11/11 #7: Squared corners on cabinet front cu ...
Thank you all for the responses!
11/11 #8: Squared corners on cabinet front cu ...
How about building the pull hole into the core? Band long strips of P Bd. Cross cut , then stack in a jig box to guide a hand held router in making the notches in a pile of them at one time. Add top & bottom oak parts as usual, wide belt and veneer. Route out the veneer and use a knife to clean corners. Use the kind of router bit that has a drill point and a solid pilot. They are widely used in the RV business. No CNC required.
11/19 #9: Squared corners on cabinet front cu ...
we have a small spring loaded l shaped chisel that futs into sn inside corner and you hit bit lightly with a hammer and it gived you averred inside corner. Think it wad from Lee Valley or woodcraft. 15.00
11/20 #10: Squared corners on cabinet front cu ...
Thank you all and have a Happy Thanksgiving!
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
