Squared corners on cabinet front cut-out
11/10/15
John S  Member
We have been asked to use a new kind of pull on our cabinets for an up-coming order. It requires a rectangular cut-out in the drawer front (see pictures) that the pull will fit into. We can CNC the basic cut-out, but of course it will have radius corners from the router bit. Any suggestions on how best to square out the corners?
View higher quality, full size image (1936 X 2592)
11/10/15       #2: Squared corners on cabinet front cu ...
Bob Harkleroad
The fronts in the photo look like they were made as a hardwood frame that may have had a rectangular opening for the pull framed into the front and then veneered over. Not making them as shown in the photo?
11/10/15       #3: Squared corners on cabinet front cu ...
John S
Hi Bob,
We are being asked to copy a now bankrupt company's product, so we're not sure. All I have is a picture. I was thinking it was hardwood banded particleboard core, but you could be right.
Thanks for the response!
11/10/15       #4: Squared corners on cabinet front cu ...
We square corners every day in plywood. We use a mortising bit in a drill press with a special placement/backer. I would probably not try it in PB. Hardwood sounds like the way to go.
11/10/15       #5: Squared corners on cabinet front cu ...
Steve Member
Corner Chisel..
Link
11/11/15       #6: Squared corners on cabinet front cu ...
dustmaker1 Member
Square is relative, I just use a smaller tool to clean out corners sometimes down to 1/16 cutter. 99% of the time 1/8 is small enough not to notice the radius. I guess it depends though on how you decide to make these and what quantity.
It does appear in the photos to be a Pb core with solid frame with veneer over, so hollow chisel may not work well. Am I seeing some Pb core at ends of pulls in openings? Solid wood may be a better choice for a small quantity then you could use hollow chisel.
To answer your original question I would probably clean corners with 1/8" tool and then a little chisel if necessary.
Paul R
11/11/15       #7: Squared corners on cabinet front cu ...
John S  Member
Thank you all for the responses!
11/11/15       #8: Squared corners on cabinet front cu ...
How about building the pull hole into the core? Band long strips of P Bd. Cross cut , then stack in a jig box to guide a hand held router in making the notches in a pile of them at one time. Add top & bottom oak parts as usual, wide belt and veneer. Route out the veneer and use a knife to clean corners. Use the kind of router bit that has a drill point and a solid pilot. They are widely used in the RV business. No CNC required.
11/19/15       #9: Squared corners on cabinet front cu ...
Harold
we have a small spring loaded l shaped chisel that futs into sn inside corner and you hit bit lightly with a hammer and it gived you averred inside corner. Think it wad from Lee Valley or woodcraft. 15.00
11/20/15       #10: Squared corners on cabinet front cu ...
John S
Thank you all and have a Happy Thanksgiving!
