Gannomat Pro-Line 50
12/11/15
Mark Elliott Member
I just bought a used Gannomat Pro-Line 50 and I'm shocked at how little pressure the hold clamps have. I can push them up with very little effort.
I'm certain this isn't normal. Am I missing something?
Thanks,
Mark
12/13/15       #2: Gannomat Pro-Line 50 ...
Mark Elliott Member
I figured out the problem. If I'd had the manual with it I suppose the answer would have been there.
I bought one because I have about 2000 drawer fronts per month the need 4 holes drilled in them on 32mm centers.
Because I'm using just 2 drills per row I was only needing 4 of the 6 clamps. And of all things when I was using just 4 clamps there was not even enough pressure to hold the pieces down when through drilling those 4 holes. As soon as started using all 6 the problem went away.
It did take me long time to figure that out though.
Mark
