Frameless Filler Option
1/16/16
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
Hello,
I'm estimating a house of cabinets. The customer wants 1.5 inch fillers and matching end panels, 1.5 also. In other words the face is 1.5 inches. Also the panel and filler
are designed to be flush with the drawer fronts or doors as opposed to set back flush with the cabinet panel face. This material is a textured laminate on MDF, not solid wood. In this scenario what methods have been used to get a nice result. It could be horizontal or vertical grain direction.
1/17/16       #3: Frameless Filler Option ...
Edi Silva  Member
Website: silvawoodworking.com
If i was in your shoes, i will get a veneer sheet of this textured laminate, double the end panel thickness to 1.5 and apply the laminate on the front edge. Same for the fillers.
Edi
1/30/16       #4: Frameless Filler Option ...
Harold morantz
Some of the textured melamine shave a matching laminate. Some don't. You can cut your 1.5" strip if you are using a horizontal match from the same sheet as the doors next to it for a perfect match and then laminate the side f the panel. Since every sheet is identical, you can get a perfect match. Trying to make a miter in this material is possible, but you will get a very sharp edge that is easy to damage. We match our horizontal grains in this material all the time. If it's vertical, the grains are usually so varied that matching is very easy.
