Cutting Starboard
1/30/16
Tom G
I recently made a small cabinet out of starboard and had problems with the sawdust / shavings from the saw kerf clogging up the dust extraction tube on my holzer panel saw.I even took the dust tube off right near the motor to let the shavings just blow out but it still would bind up inside .
Does anyone have any experience / suggestions of how to eliminate this issue , Ive got another job that will require me to cut up a half dozen sheets of this material .
Tom
2/1/16       #2: Cutting Starboard ...
Stuart
I've done this plenty of times, i just turn off dust extractor and every 'x' number of cuts clean it out. This is a bigger problem with UHMW, starboard(hdpe) is not so bad.
