Condo paneling
2/4/16
Terry Payne
Hey all,
I've been asked to bid some paneling around entry doors at a condo complex. The designer is asking how to spec out the paneling to meet fire code. This is new to me. Aside from using a fire retardant MDF core and using a water based finish, I'm not sure what to tell her.
There's also the issue of trying to match my paneling to the fired rated door. I don't know if code allows me to veneer the door and finish to match my paneling.
Normally, I would pass on this job since it's out of my normal scope. But I do a lot of work for this designer, so I'd like to at least educate myself and her even if I don't end up doing the job.
2/4/16       #2: Condo paneling ...
Alan F.
Veneering the door voids the label, the panels and doors need to be ordered in sequence from a vendor that does both. Or order a similar cut as the doors and stain to match.
If the panels don't project more than 1-3/4" from the face of the rock fire rated core is accepted in most locations. You can get class "A" non water based coatings.
2/4/16       #3: Condo paneling ...
Terry Payne
Thanks Alan.
In regards to the finish, is the finish itself fire-rated? From what I'd read I thought it was the entire panel (finish, veneer, and core) that would be tested for a certain rating.
2/4/16       #4: Condo paneling ...
Alan F.
Terry,
It depends on the local codes. Where we work the rated cores and the class a finish work in high rise elevator lobbies. If the plans call for a rated assembly then you need to buy a rated assembly, you won't be able to do it yourself. There could be a chance that the architect doesn't really know the correct code.
Where are you located and how tall is the building?
2/5/16       #5: Condo paneling ...
cabinetmaker
You may actually get away with out Class A thanks to NFPA and if it has sprinklers. Since it is wall decoration some counties or municipalities will dictate that the decorative panels can take up no more than 10-12% on wall covering in square footage related to the total wall footage.
