price for custom kitchen
3/6/16
Mike Member
I am building a custom kitchen for a customer and it's a time and material job. I'm not just a kitchen shop but i do build them once in a while. I'm concerned the price is getting to high by the time i finish the build. It is all face frame inset doors 5 piece flat panel doors. The boxes are clear lacquered 3/4 ply with 1/4 backs screwed on. The face frame and doors are soft maple with2 coats lacquer primer and 2 coats colored lacquer sprayed on. Upper boxes are a little extra deep and one of them is 15 inches deep. Applied end panels and 3/8 mdf applied to the bottoms of the upper cabinets to allow for custom lighting to be inset. Shelf supports all have the metal sleeves and the 2 large drawers are very deep for pots and pans. A second row of cabinets will sit on top of the upper cabinets with a custom molding applied over the joint and crown at the ceiling line. All face frames have been adjusted in width to allow for the correct revel after molding and what not have been applied or scribed off. High end hinges and hardware (retail over one thousand before my discount). Material will come in at about $3'750.00. Their are 32 doors including the end panels and 2 large drawer fronts. My cost to customer might go as high as $16'000.
Not being in the kitchen market i don't want to rip this guy off because I'm not set up for production work. I'm only allowed 3 pictures so i hope i can show enough detail. One picture is of the kitchen i will be replacing.
View higher quality, full size image (756 X 1024)
View higher quality, full size image (1280 X 1179)
View higher quality, full size image (1400 X 933)
3/6/16       #2: price for custom kitchen ...
Mike Member
I should have mentioned that it's in the Boston / Rhode Island market.
A few more pics of the uppers and a look at the lower floor plan were the sink is. Notice the set back and angled door unit against the odd shaped cabinet to fit a dishwasher.
View higher quality, full size image (800 X 450)
View higher quality, full size image (800 X 438)
View higher quality, full size image (800 X 436)
3/6/16       #3: price for custom kitchen ...
If you have a time and material contract, stop worrying! Unless you represented yourself as a low cost option to them, it is what it is.
3/6/16       #4: price for custom kitchen ...
JeffD
Are those 2 plans the whole kitchen? If so it's pretty small and your probably in the right neighborhood. Unless it's beaded face frames and install is included, in which case your too cheap. Send them to me for a quote, (just north of Boston), and I guarantee they'll come running back to you!
good luck,
JeffD
3/6/16       #5: price for custom kitchen ...
Chris
600-700 a ft finished delivered installed SF Bay Area...high end...meaning normal good clean work.
3/7/16       #6: price for custom kitchen ...
Kevin Jenness
I always wondered what" high end" meant.
3/7/16       #7: price for custom kitchen ...
Bruce H
"High End" is what you perceive it to be. The man wants a green suit, turn on the green light. That said you should be able to do the project for the 16K you estimated.
3/13/16       #8: price for custom kitchen ...
Mike, this isnt a shot, rather a friendly suggestion..,have you considered learning ACAD? I use to draw by hand, then I got tired of buying erasers. Lol
3/14/16       #9: price for custom kitchen ...
Mike Member
O Yes i tried and would love to be able to use some sort of computer program but i just can't get the hang of it. My problem is a forget the commands. I don't need to draw enough to remember it, I'm the guy who still doesn't use a cell phone or where a watch. Old school.
3/14/16       #10: price for custom kitchen ...
matthew
$20k+ would be a better price if you're going to do a really nice job. Don't sell yourself short.
