RTA Fittings
3/19/16
RTA Fittings
We do closet organizers, and have always used the cams that require 2 holes (20mm and 10mm). I'm considering switching to the single hole cams to free up a drill on our CNC.
Any drawbacks to using the single hole cams?
3/19/16       #2: RTA Fittings ...
I use Hettich 20mm cams on 16 mm melamine for a small production cabinet I build. The only drawback I can think of is alignment when pressing in. You have to be somewhat careful when knocking them in so they don't rotate a bit. It's not rocket science though. How do you plan on inserting them, hammer and block or hinge press? I use a hammer. It takes two blows or about 10 seconds each. I was using the plastic ones but switched to metal only because an order delay. Both have been flawless.
3/21/16       #3: RTA Fittings ...
Chris
Website: http://hofmannjoinery.com
Lamello makes the best, most versatile RTA connectors I've ever come across. I use them all the time for miters, thick stock, face fraces, sliding shelves, not much they can't do.
Lamello
3/21/16       #4: RTA Fittings ...
Zack
Have you ever thought of freeing up your CNC completely and getting an RTA insertion machine? It's the only sure fire way to make sure that your CAMs are aligned properly and it will free up your CNC machine to process other parts.
I know many closet companies that swear by this machine.
Gannomat RTA Machine
3/21/16       #5: RTA Fittings ...
RTA Fittings
Hi,
Thanks for the feedback. The cams do work well for us in our application, just wondering if there are any drawbacks to using the single hole ones. At one point we did use them for drawer assembly, but that was limited. I do remember the alignment requiring a little attention, but once aware of it they seemed to go in OK.
Will likely give them a try in a sample/mock up.
Thanks again
3/24/16       #6: RTA Fittings ...
Bruce H
A single hole cam puts all the fastening stress on the outer edges of the hole drilled over the edge of a particle board deck. Doesn't seem like the best idea to me. I use the two hole connectors. I can drill them in the CNC but use a dedicated hinge machine most of the time because it is faster.
