Dado stack has adhered shims
5/8/16
Blake Member
Website: http://heartsparkarts.com
I recently bought an old but fairly new condition dado stack from someone on Craigslist and its outer blades have shims that seem to be adhered to their inside faces. I'd normally adjust my workflow to accommodate any changes in cut this makes, however one shim is slightly mis-aligned with the arbor hole in the blade, so it's almost impossible to fit onto the arbor of my saw. Anybody have experience dealing with this, and/or removing these shims from their blades?
5/8/16       #2: Dado stack has adhered shims ...
Leo G
Soak it in acetone or Denatured Alcohol to see if the shims are really glued to the plate
5/9/16       #3: Dado stack has adhered shims ...
File the shim slightly with a round file.
5/10/16       #4: Dado stack has adhered shims ...
Adam Spees
Sell it or give it to someone else and order one of these.
Oshlun dado set
5/10/16       #5: Dado stack has adhered shims ...
Ken Member
Freud Safety Dados shipped with the shim attached. The alignment is just crummy QC. As Mark said, just file it or a simple rotary tool to clean it up.
