Edgebander glueline issue
5/10/16
Tom G
My edgebander is leaving an inconsistent glue Line which appears almost like a dotted line as you can hopefully see in this attached photo it's more noticeable on one millimeter banding then it is on thin wood or pvc tape .I would appreciate any suggestions on what adjustments to try to eliminate this situation.
Thanks Tom
Glue_line.pdf
5/10/16       #2: Edgebander glueline issue ...
TomB
A few things come to mind:
Not enough pressure on the rollers after the glue applicator, or dirty gluepot/roller, wrong temp on glue.
5/13/16       #3: Edgebander glueline issue ...
cabinetmaker
Be careful to not have too much pressure on the pressure rollers, hence squeezing out too much
I would recommend cleaning the auger/spreader and do some tape tests
