Aluminum edge band
5/13/16
al
Looking for source for aluminum edge band. Photo sent to me looks like 3/4" laminate door with
1/8" aluminum edge band. Looks to be flush with front and back of door. I was thinking T molding
but can't find anything that looks flat and flush with face. I found flat 1/8" x 3/4" but don't know how
to attach. Any info appreciated.
Thanks,
Al
5/13/16       #2: Aluminum edge band ...
Mike Member
I believe Outwater plastics (outwater.com) sells metal sheet that you use like plastic laminate. I never used this stuff but i remember reading about it. Hope this helps.
5/13/16       #3: Aluminum edge band ...
Alan F.
pricey, was recently speced on a commercial job we bid, haven't used and we gave a VE where this went away. the have a matching door pull profile
View larger image
http://www.alumprofile.com/door-edging/
5/13/16       #4: Aluminum edge band ...
pat gilbert
Did you look at Taco or Outwater or Hoskin and Muir or Cr Laurence or A George Diack?
Or just buy some aluminum laminate with out the phenolic backer and slit and use it as edge banding.
Surely you will find something that will work.
Can you screw if from the back or even use 3m double stick tape.
5/13/16       #5: Aluminum edge band ...
Tom
Website: http://TPGCABS.com
I've done a few modern kitchens with 1/8 x 3/4 anodized aluminum bar stock on the edges of laminate or wood veneer doors . Just scratch up the back of the aluminum with some 120 grit paper and glue and clamp , I use white melamine glue .Its surprising how strong the bond is .
View higher quality, full size image (3968 X 2976)
5/14/16       #6: Aluminum edge band ...
al
Alan's looks pretty easy to install but I think Tom's look with just a 1/8" square edge is
what they are looking for. I researched all the sites mentioned and can't find Tom's look
in T molding. I'll try sample and glue as Tom suggested.
5/14/16       #7: Aluminum edge band ...
Tom
Website: http://tpgcabs.com
Al
If you give me a call I'll give you a run down on how I go about this . Too much for me to type it out .
5/14/16       #8: Aluminum edge band ...
Harold morantz
What about aluminum abs or pvc banding in 1mm?
