Chop Saw Scale
5/14/16
Jon Member
I am having trouble getting the chop saw scale to match the sizes coming off the router. The chop saw is a simple dewalt compound miter saw, not a slide saw. It has a nice Biesmeyer table and stop. The original stick on scale was off as the lengths got longer. By the time you got out to 60" it was off 1/32". We lined up a couple different Stanley and other brand of tapes, and found the the saw scale gradually got out of alignment with the other tapes, verifying the discrepancy as lengths get longer.
Long story short, I replaced the tape with another stick down tape with close to the same results. The tape I put down was a Delta (Biesmeyer replacement). Does anyone know if there are differences in the accuracy of different brands.
I know printed steel tapes are only going to be so accurate, but I really do not want to go to the trouble, or expense of adding an encoder and digital stop. The Biesmeyer is easy to set accurately, if the scale was accurate.
I appreciate any comments on your experiences.
5/14/16       #2: Chop Saw Scale ...
Kevin Jenness
I think you have to order several to get one that agrees with your other references. I had a similar issue with the tape on my chopsaw (not sure of the brand) and replaced it with a Kreg metal self-adhesive tape. Both the Kregs I got agreed very closely with the rules on my slider and my current Lufkin tape measure, but I don't know if a third one would match the first two.
5/14/16       #3: Chop Saw Scale ...
Adam Spees
I would trust the Starrett above others.
Starrett Measure Stix
5/14/16       #4: Chop Saw Scale ...
Leo G
What's the temperature like when you are measuring. I'm sure the manufacturer has a specific temperature when the tape should be accurate.
5/15/16       #5: Chop Saw Scale ...
Jon Member
The shop ranges from 60 - 80 degrees depending on the season. The router sizes will not change, but the tapes that we are comparing are roughly the same temperature. The Starrett tape that Adam mentions looks a lot like the Delta tape. I wonder if in fact they are the same.
I may try getting a Kreg tape and see how that compares.
5/15/16       #6: Chop Saw Scale ...
Joe W Member
I agree with Adam. I never had much luck until I used Starrett. Now everything has Starrett in my shop.
