Best All Around Glue for Glue Pot Bander?
7/6/16
B Member
We are expecting our very first edgebander to be delivered and installed in 3 weeks (Brandt Ambition 1110). Does anyone have a good recommendation for one type of glue that will work good for both raw wood banding and PVC? I would rather not have to change types of glue in and out of the pot.
Thanks!
7/7/16       #2: Best All Around Glue for Glue Pot B ...
Jared
B:
We have the same bander, installed about a month ago. So far we've run .5mm and 1.5mm veneer coils, wood strips, and .5 PVC using Henkel Technomelt Dorus KS 351 running at 180°. It says it's a clear glue, but in the pot it looks more translucent than clear. It's performed well, no complaints. Both white PVC to white melamine and veneer to plywood look good, and we've yet to have an adhesion problem or a dry end. The Brandt tech warned us to not let the clear glues heat too long in an unused pot, as they tend to burn quicker than a colored glue, presumably because the colorants are a filler that has insulating properties. If we go on a banding break longer than 15 min, we'll turn the pot off.
7/7/16       #3: Best All Around Glue for Glue Pot B ...
Hen Bob Member
I 2nd the Dorus KS 351, we switch from PVC to wood tape constantly without any problems
7/7/16       #4: Best All Around Glue for Glue Pot B ...
B
Thank you, gentleman. I'm gonna order some right away.
7/7/16       #5: Best All Around Glue for Glue Pot B ...
I third the Dorus recommendation.
7/7/16       #6: Best All Around Glue for Glue Pot B ...
Andy
We have the same bander and run the Dorus 217 natural for .5mm pvc and 1.5mm veneer coil.
