Holzher 1303 edgebander
11/28/16
Steve Waldner Member
I have a 1303 edgebander. The problem i have is when the second endtrimmer returns to the top position it does so too fast and shakes the machine that the top and bottom trimmers shake and leave a ripple in the tape. Is there any way to slow it down so that doesn't happen?
11/30/16       #2: Holzher 1303 edgebander ...
Matt M
Our old 1411, I think, had either a bumper or some sort of air shock that helped prevent this. Have you checked to make sure that nothing is going wrong there?
Also, are you possibly running your bander on too much air pressure? I believe that trimmer has a pneumatic actuated motion, correct?
12/1/16       #3: Holzher 1303 edgebander ...
Thanks for the reply. I figured out what the problem was. The microswitch on the top of the end trimmer was wired wrong.
