Adjustable Door Stop source?
12/14/16
Bill Hager
Looking to source this adjustable door stop. Has anyone seen this before or perhaps have any brand names that might carry it? Checked the usual suspects but can't seem to find this particular model. Thanks for your help.
View higher quality, full size image (1200 X 1600)
12/14/16       #2: Adjustable Door Stop source? ...
D Brown
In a pinch you may be able to use an after market soft close, that can be placed closer to the opening edge .There are several available.
12/14/16       #3: Adjustable Door Stop source? ...
cabmaker
We use these all the time.
Hafele 246.15.610
The strike plate, however, is different than what your picture shows. The actual strike that ships has a gimbal effect that rotates to better connect with the magnet. This strike has a press in fitting that also requires a slight dimple in the back of the door.
It's a great piece of hardware.
12/15/16       #4: Adjustable Door Stop source? ...
Dan
Yes, Hafele has these in Nickel Plated and oil rubbed bronze finish with flat strikes and with round knock- in style.
