Dynadro Please check my math
1/5/17
Barry
Hi
I did a spreadsheet to determine the new drawer opening heights I`ll need when using this undermount. Dovetail drawers from my supplier are 4, 4 1/2, 5 (Height)
I came up with 1/4 top clearance and 9/16 for bottom clearance. So I determined the heights from 13/16. I rounded up the value by 1/16.
The true value was a bit less then 13/16. So the current issue is the height of the sides of the drawer. And their relationship to the RO. Hope I`m clear on this.
View higher quality, full size image (662 X 696)
1/6/17       #2: Dynadro Please check my math ...
Adam B Member
Barry,
your math looks good, except you are shorting your self 13/16" of usable drawer space in the final column. Typically a 4" tall drawer box would have a 1/4" thick drawer bottom set up 1/2" from the bottom of the drawer box.
4" tall drawer box - 1/2" clearance - 1/4" thickness of drawer bottom = 3 1/4" usable drawer box. You could also include in that number the 1/4" clearance that you are shy of the top rail, so essentially you could set anything in than drawer as long as it was less than 3 1/2" tall and the drawer would still close.
1/6/17       #3: Dynadro Please check my math ...
Barry Golash
Hi Adam
Thanks for the help. I see what you mean regarding the useable ht. I`ll make changes to the spreadsheet.
Thanks again. Barry
