Guillotine cutting problems 3mm PVC
1/26/17
Knick  Member
Website: cmsdisplays.com
Hey guys!
We have two banders Biesse and Giben.
Biesse we have had for awhile and it sometimes will cut 3mm wood tape and other times wont. 3mm PVC it cuts fine.
The Giben is new to us and I am still trying to dial it in. This machine wont even cut 3mm PVC consistently. Guillotines are sharp air pressure is within specs. Running strips is a pain and I was wondering what you guys do? Any tips you can share? or do you just run strips if your machine wont cut 3mm?
I wish we could just use 2mm and under :)
Thanks for you time!
1/26/17       #2: Guillotine cutting problems 3mm PVC ...
We run lots of 33m PVC and some of the veneer. Check the alignment of the guillotine knife to the anvil. If everything is properly set up and it still has trouble, I'd turn the pressure up a bit at a time until it works. The recommended settings sometimes need to be treated as a starting point. 3mm woodtape is pretty tough stuff, your machine might not be built strong enough to handle it.
1/26/17       #3: Guillotine cutting problems 3mm PVC ...
Jared
On my first bander, I ran into the same problem with 3mm wood banding (an old Brandt machine circa 1986). After replacing the air cylinder, I had the guillotine blade sharpened with a much steeper skew angle and it solved the problem completely.
1/30/17       #4: Guillotine cutting problems 3mm PVC ...
Knick  Member
Alignment on the knife is good and the air pressure is not adjustable (its full line pressure) I did find the muffler/silencer on the exhaust side of the cylinder was restricting air flow somewhat. I removed it and have yet to to test it. I will follow up with what I find. Thanks for the feed back guys!
