Wall Safe
2/6/17
Tom
I have a client that wants a wall safe hidden behind a unit I am building for them . I've been looking at safes on line but it's hard to determine the quality . Can anyone recommend a safe they have used that is both reasonably burglar proof and reasonably fire proof ?
2/7/17       #2: Wall Safe ...
I have always asked the owners or the design professionals to pick out or specify a safe. I'm no expert, and should there be a problem down the line, I could have some liability. So, I quietly exclude that and then make RFI's to get info so our work will work with it.
Don't let them put that onto you. Your work will be challenging enough to perform, without the added burden of selecting such an important item.
If they insist, then I'd select one that completely exceeds all their requirements, and do all the research, Woodwebbing, etc. at your shop rate.
2/7/17       #3: Wall Safe ...
cabmaker
Your cabinet will have two doors: The door for safe and the door for the cabinet.
In order to provide fireproofing the door for the safe will be quite thick.
The thickness of the safe door makes it hard to access contents when safe door is at 90º open.
You will likely need extra space in the cabinet (on safe hinge side) in order for safe door to swing wide enough to provide comfortable access to contents.
