Holzher Edgebander
2/22/17
Nat
Anyone have any experience, or feedback to give on Holzher's 1302 edgebander? I'm a one man shop, doing stricly 1mm banding and am starting my search for a new edgebander.
Thanks in advance.
2/23/17       #2: Holzher Edgebander ...
I have a 1302 as well and edge band 1mm and 1.3mm PVC with no issues. I have not tried solid edgebanding in those thickness.
2/23/17       #3: Holzher Edgebander ...
Stu
Thanks very much for the reply. Can I ask, have you found it to be fairly user friendly, and not require too much tinkering to keep it dialed in?
2/23/17       #4: Holzher Edgebander ...
aj
Im also curious abolut this. I have a smaller glue pot and was wondering if the glue cartridge setup on the 1302 works well before dropping 28k. thx
2/23/17       #5: Holzher Edgebander ...
Once you have it set there is very little adjustment. Tweaking the stations is very easy.
I've had no issues with mine, but you have to keep it clean and maintained, just like any edgebander.
I used to have a Cehisa EP2 edgebander, gluepot, cutoff knife. Going to the Holzher was a major step up.
Takes less than 5 minutes to heat up your edging. Changing glue colour takes a couple of minute to purge (manually).
2/23/17       #6: Holzher Edgebander ...
Aj
Thank you. Anything you don't care for on it?
