Furniture Grade End Panels
3/16/17
Family Man
If I say furniture grade end panels what does that mean to you as a cabinetmaker and designer?
How do you denote a slab vs 5 piece end panel?
Thanks-
3/16/17       #2: Furniture Grade End Panels ...
james e mcgrew Member
Sorta depends on the quality of the sec and spec writer, if unspecified i generally presume end panel is to match doors and drawers, and RFI to the spec provider would be a good idea.
3/16/17       #3: Furniture Grade End Panels ...
JM
I note "Decorative End Panel" or "Slab End Panel" on elevation views.
3/16/17       #4: Furniture Grade End Panels ...
Carmine Member
I would interpret furniture grade as a door matched EP or some type of applied molding/design. I prefer to word the specs as such to avoid confusion.
3/16/17       #5: Furniture Grade End Panels ...
D Brown
To me furniture grade has to do with the quality not the type of end panel.
I call out frame and panel ends either flat panel or raised panels.
3/16/17       #6: Furniture Grade End Panels ...
Doesn't mean anything to me. I build everything to the same quality.
3/18/17       #7: Furniture Grade End Panels ...
chuck crawford
With no other information, I would assume a panel to match the doors.
