Hardware before assembly?
4/1/17
Stewart Member
We generally like to apply common hardware (like hinge clips and drawer glides) "in the flat" when we can get to it more easily. (We do the more complicated hardware - like pantry systems - after assembly.) Do you guys find this makes your assembly harder with hardware already applied or do you find it more time saving to wait and apply everything after assembly?
4/1/17       #2: Hardware before assembly? ...
Paul Miller
We build mostly Frameless, Euro style cabinets and that is how we do it. Base plates, drawer guides and Keku clips if they are needed are put on the side panel before assembly. Specialty hardware such as Lift up mechanisms used for Mixers and hardware for pull out trash are installed after the cabinet has been assembled.
4/1/17       #3: Hardware before assembly? ...
Jim K
We install all hardware flat before assembly. Found it faster than after assembly.
4/1/17       #4: Hardware before assembly? ...
Dan cook
Same here all hardware goes on flat whenever possible.
4/2/17       #5: Hardware before assembly? ...
chipbored
Same here. I ask that cabinet leaves assembly bench with "as much done as possible".
- Hardware on, cleaned, labelled, infills on, end panels on. It's the most efficient way and the most comfortable working position for your staff.
4/5/17       #6: Hardware before assembly? ...
Stewart Member
Thanks, guys! That's how I've always thought about it but just wanted to make sure I was thinking straight. We just split the hardware up into two phases - what we can put on before assembly and what we can't.
