How to affix end panels to prefinished plywood
4/5/17
cabmaker
We build a cabinet that has end panels mitered to faceframes. The box itself is either made out of pre-finished maple plywood or if the cabinet is paint grade out of raw plywood.
We need to come up with a better way to affix to the end panel to the cabinet box.
We currently juxtapose the faceframe to the box however meets the condition we need to see on the inside. What we struggle with is how to shim and affix the end panel, particularly to prefinished plywood.
The distance that needs to be shimmed varies depending on the situation. Our current strategy is to produce shims as necessary then affix them to the box. If the box is prefinished plywood we first abrade the plywood with a hand held belt sander so that there is something for the titebond yellow glue to get purchase to.
I am thinking that it might be better to use a panel adhesive that comes out of a caulk gun. The adhesive being pliable could perhaps act as the shim as well as the glue mechanism. Adhesive that comes out of a caulk tube is pliable so we would only need to hold the panel square and to position until the glue set up.
If we could get an adhesive that would stick to the prefinished plywood we would also no longer need to do the scratch pattern with the belt sander.
Does anybody have a better idea for how to join the end panel to the prefinished plywood panel?
Any suggestions for what kind of glue would be mooshable enough to act as a shim? (something relatively non-toxic).
Are there any delivery mechanisms for applying the thick glue that wouldn't involve a lot of squeezing by hand on a caulk gun?
4/5/17       #2: How to affix end panels to prefinis ...
jtwoodworks
Not sure how well it would act as a shim, but recently I glued two prefinished pieces together using gorilla glue construction adhesive and was surprised how well it held. The shop I work at usually uses one sided prefinished for cabinet boxes so we don't come across this issue too often.
4/5/17       #3: How to affix end panels to prefinis ...
cabmaker
Thanks JT,
I am hoping to get some kind of cushioning effect from the glue as well as adhesion.
What put me onto this idea was how plywood subfloors are bonded to floor joists. The glue provides some adhesion but mostly it is the mechanical fasteners (nails or screws) that do the heavy lifting. The bead of mastic itself mooshes into the low spots where the lumber isn't perfectly straight. In this case it acts as a gasket to absorb discrepancies and minimize squeaks.
I was hoping that the mooshable element of the glue would help bridge distance between plywood box and interior face of end panel.
4/5/17       #4: How to affix end panels to prefinis ...
jtwoodworks
Yeah I see what you mean. I've done the shim in the past like you do. I've also just lined up the mitre on the face frame as close as possible to the outer edge of the cabinet side. Both ways are kind of a pain.
4/5/17       #5: How to affix end panels to prefinis ...
Is mooshable a word?
4/5/17       #6: How to affix end panels to prefinis ...
cabmaker
Yes.
That is the metric spelling.
4/5/17       #7: How to affix end panels to prefinis ...
Matt Calnen
I screw mine on from the inside. Staple the shim piece on from the outside. If possible use trim head screws in the linebore holes.
4/5/17       #8: How to affix end panels to prefinis ...
In order to gain purchase on the prefinished ply, experiment with PL.
4/5/17       #9: How to affix end panels to prefinis ...
cabmaker
What is PL?
4/5/17       #10: How to affix end panels to prefinis ...
Check this out Tim
Sticky stuff
4/6/17       #11: How to affix end panels to prefinis ...
Joe
Website: http://joescustomcabinetry.com
We apply the frame to the endpanel then send it for finishing. The UV box is sized to have a 1/32 or smaller gap to the end panel.
Our box has a 3/4 back that rabbets in. Before the back is installed we can countersink 1 1/4 screws thru thecrabbet into the end panel.
4/6/17       #12: How to affix end panels to prefinis ...
Skip the glue. Fasten your fillers to the prefinished ply with a 1/4" crown cabinet stapler. Screw from inside the box thru the shims and into the panel. You can use regular #8 cabinet screws.
Try to pull a piece of ply stapled to another piece of ply. You will need a hammer a pry bar and you will end up destroying the ply. Staples hold much better than nails.
4/6/17       #13: How to affix end panels to prefinis ...
JeffM
Just curious...why the miter connection from frame to panel?? Seems like one more place to open and separate later and much more work. I also screw my panels from the inside of the box, but run my ff 3/4 long of the box and put a small 1/8 radius on the back side of the ff and the front of the applied panel. Looks pretty nice and pretty fast easy to do.
4/8/17       #14: How to affix end panels to prefinis ...
Cabmaker
JeffM,
The reason we miter the corners is that it produces a joint that makes the segue from exactly at the corner. This helps minimize any wood movement from telegraphing through the paint.
Depending on the application we do use small rabbet joints from time to time. The exposed edge of rabbet is no more than 1/8 inch thick. This much change up in material can get masked by the brush strokes in the paint. The final coat on all of our work is brush finished.
4/8/17       #15: How to affix end panels to prefinis ...
Cabmaker
Pat,
That is a great glue! I brought some in and did the following tests.
The glue pattern was a simple square pattern around the perimeter with an "X" in the middle. The only clamping pressure was an initial push together with my fingers.
We tested this with:
A) Raw paint grade plywood >>> Scuffed up Pre-fin plywood. The scuffing was a quick dust with a handheld belt sander at 80 grit.
B) Prefinished plywood >>> Prefinished plywood. This was just as it comes off the truck
C) Raw paint grade plywood >>>Raw paint grade plywood
D) Raw paint grade plywood >>>> Raw prefinished plywood without any intermediary scratch patterns on the prefin.
View higher quality, full size image (1794 X 1386)
4/8/17       #16: How to affix end panels to prefinis ...
Cabmaker
As I said before, there was no clamping pressure other than what you could apply with your fingertips. The gluing time was about 18 hours.
We then tried to pry these apart laterally using a lightweight clamp, a bar clamp and a hammer.
Nothing would make the joint budge.
View higher quality, full size image (2200 X 1092)
4/8/17       #17: How to affix end panels to prefinis ...
Cabmaker
Note that our attempts to separate the pieces were all on the Prefin >>> Prefin sample. Our reasoning was that this would intrinsically be the easiest joint to break.
4/8/17       #18: How to affix end panels to prefinis ...
I take it that it stuck then?
This is not as sticky a subject as politics, if someone could bottle the substance that makes people stick to their political ideology
that would be the best of glue of all.
4/8/17       #19: How to affix end panels to prefinis ...
Cabmaker
We were finally able to separate the parts when we drove a chisel through the joint as a wedge.
The pieces popped apart nicely and you could pull the glue off the prefin with your fingers like it was a simple butyl caulk.
View higher quality, full size image (1386 X 1794)
4/8/17       #20: How to affix end panels to prefinis ...
Cabmaker
Curious now as to how well this approach will perform in acting as it's own shim.
What put me onto this shim idea was how the stone countertop people install their work. When two pieces of stone are seamed together they first drop down a bed of butyl caulk and then put four dollops of bondo in the corner.
The bondo sets up quick and keeps the stone from settling. The caulk cures as it would normally. They only have to hold the pieces in alignment long enough for the bondo to set up.
4/8/17       #21: How to affix end panels to prefinis ...
So in sheer it tests well, but not so much on tensile strength?
Are you over thinking this?
What are the odds that your panel will have to withstand a wedge?
4/8/17       #22: How to affix end panels to prefinis ...
Cabmaker
We can find a way to get politics in here.
Think for a second about the scientific method. First you make the hypothesis then you test it.
The validity of the test would have a lot to do with how the hypothesis is framed. How you interpret the result would define what is or is not legitimate to consider in subsequent study. The results of subsequent study would therefore always corroborate the initial fundamental assumptions.
If, for example, you ask the question: "Should elected officials be able to grope women who work for them" everybody can agree that this would be wrong in every instance.
If you reframe the question, "Should Donald Trump be allowed to grope women who work for him" the answer will be that this is just "locker room talk."
See how easy that was?
4/8/17       #23: How to affix end panels to prefinis ...
Cabmaker
You are right that sometimes I do overthink these things.
Sometimes, however, I tend to underthink them.
It all balances out.
4/8/17       #24: How to affix end panels to prefinis ...
The scientific method is useful to test things to gain knowledge. BUT not all things.
a posteriori (the scientific method) is great for testing glue joints, rocket surgery, and computers.
Not so much for psychology, mathematics, or economics.
a priori is how math is done, through proofs or axioms.
The reason economics does not lend itself to a posteriori is because economics is not a controlled experiment.
7 billion people make an average of what 10 transactions a day. It is hard to have a controlled experiment on 70 billion transactions a day.
Most economists try to use a posteriori on economics. Which is bat shit crazy.
Politics is a similiar type deal.
At the very least critical thinking is useful on this and many subjects.
4/12/17       #25: How to affix end panels to prefinis ...
Pdub Member
Just a story about PL Premium's tenacity.
First off, I should say that it has somehow took on the name "Pooky" in our shop and the installers and GC's have joined in with that too. So much so that it has turned into a verb. "Just pooky it in there and it won't move."
Years ago we put a large bookcase into a large house. We "pooky'd" 2x blocks to the floor in the corners of the toeboxes instead of screwing them down because of radiant floor heat. 5 years later the new owner of the house wants a different unit built and installed. We go to remove the old unit and have to pry up those 2x blocks. They came up alright, but only by taking substantial chunks of the solid maple floor with them!
4/12/17       #26: How to affix end panels to prefinis ...
pat gilbert
You should have used a shim. (8^())
5/17/17       #27: How to affix end panels to prefinis ...
I like Matt's idea of screwing through the line boring holes. We screw all our finished panels and fillers from the inside of the box like others using #6 or #8 wood screws. The biggest reason for doing this is in case you have to refinish any of these pieces because of damage caused by the homeowner or if an end panel checks because the sun is shining on it through a window or something, It is easy to send a guy, pop a few screws out and bring the piece back to be touched up.
