Dowelled Drawers
4/18/17
Barry
Website: http://www.woodsolutions.com/
Has anyone used dowelled drawers from Keystone Wood Specialties. Am wondering about the strength of a dowelled drawer versus a dovetail. We have a job with a few drawers that are 46 wide, 34 deep and 12 high. A dovetail drawer quoted was $320.00
May have to try dowelled construction to save money.
http://keystonewood.com/dovetailed-drawer-boxes/doweled-drawers/
Keystone dowelled drawers
4/18/17       #2: Dowelled Drawers ...
FWIW I was told that the doweled drawers are actually stronger than dovetailed.
Also I have never had a drawer fail (that I know of). Almost all were just pin nailed or stapled.
4/18/17       #3: Dowelled Drawers ...
Rich  Member
we only use dowel construction in commercial casework and never have issues.
For a drawer that size we would use 3/4" material for box and 1/2" for the bottom. The bottom would be in a dado and screwed into front and back of drawer box.
4/18/17       #4: Dowelled Drawers ...
The only damage I've ever seen to any drawer is the cheap ones with 1/4" hardboard bottoms that buckle and the whole thing blows up.
Its not like you are taking a drawer and throwing it on the ground. Any well constructed drawer will last forever.
Keystone is a good company. We've bought dovetail drawers from them in the past.
4/19/17       #5: Dowelled Drawers ...
Dan cook
We make our own drawers and have been doweling them since the 80's. I have yet to have one come apart. I prefer the hidden joint to dovetails. To me it is cleaner looking.
4/20/17       #6: Dowelled Drawers ...
Paul Miller
What are the drawers going to be used for?
I don't think of Dovetail drawers as being strong, but rather appealing in appearance.
I have never used the doweled drawer so I can not give an opinion on that. You will probably have to use side mount guides like an Accuride.
If I could, I would make the box from 3/4" plywood and screw it together and I would probably dado the bottom in and also run screws in to the bottom along the sides, front and back if a lot of weight was involved. Half inch bottom would be a must or even a 3/4" depending on the weight.
Depends on the application.
4/20/17       #7: Dowelled Drawers ...
Bruce H
We make drawers that big using 3/4" melamine (plywood would work) and screw them together using comformat screws. 3/4" sides and 3/4" bottom. Treat it just like a cabinet.
4/20/17       #8: Dowelled Drawers ...
Harold
We make our own drawers using either 1/2" ply /white liner for bottom and sides and 3/4" for fronts and backs. We only use undermount grass soft close, so bottom is pocket hoed to sides 1/2" up to allow for track and if sides are 8" high, then front and backs are 7" high. We bail and screw the 1/2 " bottom to the front and back and then picket hole the front and back to the 1/2" sides and picket hole the bottom to the sides from underneath. We have a production pocket hole machine for this but a 400.00 Keegan portable will do the same thing. I can stand inside a 36" cabinet drawer with no damage to drawer or track and I weigh 180kbs.
5/3/18       #9: Dowelled Drawers ...
We only do commercial work and unless someone wants dovetails our standard is doweled 3/4" melamine with 2mm PVC banding. no known failures. Done on CNC automated equipment.
