SCMI R9
4/28/17
keith farr
I have an SCMI R9 overarm router and can figure out how to remove the guide pin. I know it can be removed because there is another size pin on the opposite end of the shaft. Also how do you get the guide pin and thebit exactly centered on each other ? is their some type of cocentric aspect to the pin houseing? Hopeing to figure that out when I get the pin out.
5/1/17       #2: SCMI R9 ...
I suggest you try to find a person that has real-world experience with overarm routers. Your question is basic and valid, but those machines scare me more than any other in the shop. For every shaper "problem" I saw, there were 10 with the OAR. I would reliably throw large boards across the shop.
There is a proper way to use the machine, but I don't know it.
As for the pin, the machine we used had a pin support that was in a machined, cast housing that could be loosened and re-centered. This would be considered extreme.
